Mystery screw for cabinet hinge
Jun 15, 2012
715
BAVARIA C57 Greenport, NY
I lost a couple of hinge screws when I had to remove some cabinet doors on my 2007 41DS. The screw holds the door hardware on the stationary bracket on the cabinet. I tried to match up the screw at HD but neither metric or standard screws matched up. The hinge is a "european type", but has no identification on it. Anyone know what is size of the screw and where I can get a replacement?
May 25, 2015
176
Macgregor, Hunter Venture 21, H25 Candlewood
Get me a picture and measurements and I'll see what I have in the shop.
Benefits of being a cabinet maker
Hunter 29.5 Gloucester, VA
Probably one of the adjustment screws for the hinge which are not standard. Blum hinges are pretty cheap, you can just replace the hinge. But like John says post a pic of which one you need.
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
stop by any cabinet shop in your area and ask them if they use blum euro hinges and if yes they will more than likely give you one ..most cabinet shops have a good bunch of folks working there and if not i can send you one out of my stock just send me a pm
