Mystery oil leak
163
Oday 34 Wauwatosa, WI
I have an Oday 34 - just launched about 4 weeks ago for this season. Never had an oil leak (except when I had to replace the sending unit last year) other than the slight weeping I would consider normal for a 24 year old engine. Last week, I notice a small amount of oil in the bilge, and when I looked at the sump under the engine, it had a considerable amount of oil in it. I looked the engine over carefully and don't see anyplace that looks suspect for producing that amount of oil. The oil in the crankcase is between half and 3/4 full. I don't recall where it was when I launched. We don't have more than an hour or two on the engine this season, so I am pretty sure if it were coming out of the engine somewhere I would be able to spot the location. I cleaned the engine and bilge today, and will monitor it closely, and I did get some dye to put in the oil for inspection with an ultraviolet light. I also checked the drain plug, which I know some have a tendency to back themselves out. I am wondering now - and I didn't think to check it - if it could have come from the transmission. I was sailing last week with my daughters, and I seem to recall coming in and finding that the transmission had been in forward gear while we were sailing. I know this is taboo with the Hurth HBW50 that I have, and I am wondering if somehow this could have forced oil out of the gearbox, or crankcase?
higgs
Aug 24, 2005
3,738
Nassau 34 Olcott, NY
Time will tell
It sounds to me as if you have this pretty well covered and will come up with source of the problem soon. I thought I had an oil leak on my Yanmar and after close inspection I found that it was the o ring on the filler cap. I hope your solution is as easy.
Oct 15, 2004
163
After further research -
I don't believe it can be transmission oil - the transmission specifies Type A which I was unfamiliar with, but in researching it - I see it is just ATF, which is red. I am anxious to see where the dye turns up, but a little leary about using the engine much, since it seems most of the oil I found has come out in a relatively short period of time.
Aug 9, 2005
772
Hunter 28.5 Palm Coast, FL
check to gasket between the fuel pump...
and the engine block. The only leaks I've ever had have been there. Tighten the two bolt.
