Bill Perry
When I went to my boat this spring, I discovered that the starboard floorboard in the aft cabin had begun to turn dark on the 3 inches adjacent to the removable center section. Upon taking it out, I discovered that it was all wet and also that the engine bilge had some water in it even though the boat has been out of the water. There obviously is a leak somewhere but the source is not at all obvious. Has anyone discovered a similar problem? Since nothing is obviously wet above this area I would suspect that perhaps the extrusion that holds the plastic companionway hatch boards may need to be rebeded??
