Mystery Bolt in Bilge
Apr 27, 2016
19
Hunter 33 Detroit
I discovered a bolt in the pan underneath the engine of my 2009 H33 after a recent trip. I assumed it was one of my motor mount bracket bolts (roughly the same size), but after careful inspection none of them appear to be missing. My next guess was the bolts holding the transmission to the engine, but again nothing was missing. The engine feels and sounds just as it always has. I am at a complete lose as to the source of this bolt. This is a long shot, but I thought I'd throw it out there to see if maybe someone else has experienced this.
May 12, 2004
1,505
Did you check under the motor? Could be a bolt from the oil pan. How about a bolt from a belt tensioning arm ? I think what you'll have to do is give your motor a total inspection. For what it's worth, maybe we could have a contest. Whoever guesses it wins bragging rights. These are my two entries.
Feb 13, 2016
551
macgreggor venture 224 ohio river
Most factory engine bolts are painted, so I'm going with an accessory of some kind probably the "flux capacitor"
Could be one of the bolts a BMW lost and forgot to tell the Previous Owner.
kito
Sep 13, 2012
2,011
It's a metric bolt. Most likely came off something made outside of the US.....like an engine ;) It's clean so maybe check your alternator mounts?
Jul 14, 2015
840
Catalina 30 Stillhouse Hollow Marina
Does not appear to be any wrenching marks on the head.
1,165
Leopard 40 Jupiter, Florida
Some additional hints - Googling PB 8.8 indicates that it is a Portland Bolt equivalent to "Heat treated medium carbon steel" in nature http://www.portlandbolt.com/technical/faqs/imperial-astm-equivalents-for-metric-grades/
Unfortunately, I can't figure out the dimensions due to the non-standard measurement device you're using. Is that some sort of deer on that strange coin? :)
Due to lack of engine grime and paint, unless you have an unusually clean engine, I agree that it's not from the main body of the engine. Where was it found (front / back, side, etc.) and do you think it moved around much since dropping?
On a related note, I think it would be a great joke to get a handful of similar bolts and drop them around engine compartments next time I'm on someone's boat! :biggrin:
Apr 27, 2016
19
Hunter 33 Detroit
LOL!! These responses are cracking me up.
The bolt was towards the front of the engine (although the pan does slope towards the front). Even so i think i will remove the belt cover again and take another look. Thanks for the responses. I'll keep you posted.
Mar 2, 2008
406
Cal 25 mk II T-Bird Marina, West Vancouver
"Unfortunately, I can't figure out the dimensions due to the non-standard measurement device you're using. Is that some sort of deer on that strange coin? :)"
I think he used a metric measuring reference because it is a metric bolt.
Apr 27, 2016
19
Hunter 33 Detroit
Mystery solved! kito nailed it...turned out to be the upper alternator mounting bolt. Thanks for all the responses.
Sep 8, 2014
2,551
Glad you found out where it went, and an important one too... That would drive me crazy, I was having Obsessive Compulsive fits and its not even my boat!
Feb 13, 2016
551
Yeepee! Always a uneasy feeling seeing extra parts, wait I'm a mechanic im use to it!:yikes: ;)
Jul 7, 2004
8,542
Hunter 30T Cheney, KS
Good thing you persisted in finding where it went. Could have gotten expensive if the alternator bracket casting broke off from the vibration! :thumbup:
JamesG161
Feb 14, 2014
8,111
Hunter 430 Waveland, MS
Boy! Don't tell your marina friends that. They would go to their "old nuts and screw bin", get some weird ones, and put them all through your boat like an easter egg hunt.:laugh:
Jim...
jtm
Jun 14, 2004
314
Hunter 28.5 Dataw Island, SC
Interesting things one finds in a boat.
It must have been several years after I bought my new H28.5 when I found a strange looking shaped 8 ish inch (IIRC) casting with loop hole on one end buried under the holly/teak floor.
I just put it to the side as I had no clue to what it went to.
Then when my shift lever/cable stopped functioning and I pulled the compass and shifter head off the pedestal. I then found where it should have been affixed, it was the stand off for the shifter cable and without it had been flexing the cable ( until metal fatigue broke the cable) instead of being held straight and pinned by that casting. The cable sleeve should have been fitted into that loop.
jcela
Jul 7, 2004
20
Hunter 29.5 Kemah
I am amazed about the common interest among sailors of all around the world to help another sailor in distress, this is a great feeling knowing that there is a significant amount of knowledge ready to help and all we have to do is just ask.
Now that the enigma has been resolved I would like to share a funny story from sailing in Buenos Aires, there was this old racer that always carried with him in his regattas few small bolts or pieces of mast hardware and with a sling shot he would throw one piece of hardware against the top of the main of the rival boat and when the piece will hit deck, the crew will start desperately looking all over their rig, trying to figure out where did the strange piece of hardware came from, that distraction always was enough for him to take the lead. I am glad that was not the case of Domingo. Happy sailing.
