Hi,
The mast to my 1978 O'day 22 broke off in a storm a few weeks ago. I fixed the mast and replaced the section of the backstay that broke (called the "backstay tailpiece" on the O'day 22), but then when I stepped the mast the backstay and forestay were absurdly loose--even after I tightened all turnbuckles as far as they could go.
The replacement backstay tailpiece is very close to the same size as the old tailpiece, so the backstay is not measurably longer than it was before. The forestay is exactly the same as it was before the mast fell. Although the mast cracked off its base when it fell, I was able to fix it without altering the size of the mast at all, and the mast does not appear to be bent.
Any ideas on why my rigging is so loose?
