My unscientific battery endurance test!
Sumner
Jan 31, 2009
5,254
....Should I also have a fuse in the neg wire up close to the battery? I figured the one on the positive side was enough...
No, the one next to the battery on the positive side is what is required. Not sure why he wired it the way he did and I'd change the main switch to the positive side also.
Since the boat is fiberglass you could control the circuit on the ground side but I sure wouldn't and can visualize some situations that might occur that might not have a happy ending. If the positive side can find another source to a ground then the switch on the negative side won't turn the battery off. On the positive side you for sure are going to turn the power off,
Sum
[FONT=Arial, sans-serif]============================[/FONT]
Our Endeavour 37
Our MacGregor 26-S Pages
Mac-Venture Links
