How about covering?
I have always used 8-10 coats of varnish (less than that won't hold up to even 1 year in the South Texas SUNSHINE and year-around sailing). I love the look, but the application is a b---h. The 1st three coats each need a good 8-12 hours to dry (read apply 1/day), then the following coats need 24-48 hrs/day curing/drying time. This process takes about 20 days just to apply the varnish.A good friend just made me a new set of teak hatch boards and treated them with 5 coats of Cetol Lite and 3 coats of Cetol gloss. THEY ARE BEAUTIFUL!!! and almost as pretty as varnish. I plan to use this approach in the future.Notes on teak:1) NEVER use a scrub brush. The grain of the teak is composed of two different textures. The dark is hard and the light is soft. To get a smooth finish, you sand down the dark. If you use a brush, it will dig out the soft and make the grooves deeper which will catch more dirt and cause a rougher surface.2) Chemical cleaners are usually harsh on wood. On teak, they usually strip out some of the oil that makes teak so practical for marine uses. So if you use a cleaner/stripper (I never use them on teak) you need to recondition the wood with an appropriate product. Preventing the UV damage (SO important in South Texas!).I used scraps of Sunbrella and made covers for my handrails and toerails. On the handrails, I have installed snaps on the ends and velcro in the grab areas to keep them on. On the toerails, I installed snaps at the ends and 1-2 on each side depending on how long the rail is. The covers were fairly easy to make after I designed how to cut/fold/sew the ends. If you want a copy of my design, I'll be happy to scan and email it to you.It only takes about 5 minutes to put on or take off all the covers. I used to varnish almost every year, now by blocking the UV I can go 3-4 years. I'm anxious to find out how long the Cetol will last when it is covered.BTW, Hancock Fabrics has an outdoor fabric similar to Sunbrella in green, blue, white and black (I haven't found the burgandy) for about $8/yd. I got some once on clearance for $5.50/yd. I think it would work fine for the covers.Hope this helps.Jim
