Direct link isFor a great how to video on spring lines, search you tube "stress free sailing ". Most of the line stays on deck, the free end never comes near the prop, slick.
At our marina here in GA, we've been hit twice while in our slip, once by unknown (Highly suspected though) and once witnessed firsthand. Both vessels were trying to dock stern first in a stiff cross breeze. Almost hit by a vessel docked at the pier behind us, also while he was trying to back stern first into a stiff breeze. None knew anything of using a spring line.Just curious, why does the marina not allow stern In?
Bob
Some are concerned with prop wash (power boats) eroding the seawall.Just curious, why does the marina not allow stern In?
Bob
If you turn the helm so that your stern is swinging to port when you put her in astern, it will all even out and you won't have so much prop walk to stb. Remember, your boat turns around the center.the starboard walk takes me away from the dock.
Have you tried getting that headway with a burst of reverse from your engine, rather than physically pushing the boat? I've found that a jolt of high-rev engine for two or three seconds, then return to neutral, will give you the aft motion without the accompanying prop walk of keeping the prop moving at slower revs. Repeated bursts of reverse and coasting can continue your motion. It does take some practice if you have a split transmission / throttle levers like we have in the older Cats.I've learned to get some reverse headway going with a push-off from the dock, with the rudder centered,then jumping aboard, and putting in reverse. Once it's in motion it will go where you point the rudder.
That is exactly the point of the post initiating this thread. Giving her enough to get going is made much easier by simply using that line around the cleat and back to my hand. I am in easy control of the angle of the boat and how much speed I get because I am the one letting go the line. I no longer need to give her that big push from the dock and then race back to the wheel in the tight quarters I have. When I tried a big shot of power she moved some amount to port initially and then I was having to deal with the angle right away....perhaps with more room it would be better. Our last slip had tons of room in the pen and once out into the fairway so I didn't have to worry. The difference of 8' between boats and 3' seems enormous!Have you tried getting that headway with a burst of reverse from your engine, rather than physically pushing the boat? I've found that a jolt of high-rev engine for two or three seconds, then return to neutral, will give you the aft motion without the accompanying prop walk of keeping the prop moving at slower revs. Repeated bursts of reverse and coasting can continue your motion. It does take some practice if you have a split transmission / throttle levers like we have in the older Cats.
Dan: Do a forum search for "prop walk" and you'll find more info on the subject than you'll know what to do with. Do another search for "prop walk is your friend on the sail trim forum" and you'll find info as to how I used prop walk to my advantage. At my dock I needed the stern to turn to starboard in the slipway. The first step is obvious -- rudder is centered and engine in slow reverse. The second step is not so obvious -- once about 3/4 of the boat is out of the slip I put the engine in forward. Sounds weird but the stern slowly turns to starboard.I am in a new slip this year which is meant for a 25' boat and my boat is 33' and my neighbour is a 30'er. Being on the starboard side of the slip and little room (less than 4') between the boats, I have struggled a bit with prop walk to port as I go to back out.
Dan
That is a basic no-brainer. However, starboard tie up allows the boat to face the channel entrance and prevailing wind direction. The boat sets better with the bow facing out, and when departing, I don't need to make a 180 in the fairway.Doug. Just wondering, what if you approached the sea wall from the opposite direction? Would that make your Port walk help you?
