Have you looked at the installation manual?I did notice that the replacement pump, (original part no longer made) has the discharge angled north instead of east like the current pump discharge. I’m wondering if that can be changed and if not,
It didn’t come with one. I looked on line at Jabsco and didn’t see anything. Checked YouTube alsoHave you looked at the installation manual?
I have a tank level monitor for every tank on the boat next to my electrical panel at the nav station. Water tanks and holding tanks indicatorAnother vote for a monitor system. If you have a plastic tank it is even easier to install than my metal setup. Indicator is just above the toilet.
Eweeee I bet. I bet that was funAs nasty as that job is you should feel fortunate your macerater is not mounted directly to the tank.
Not a bad ideaI added a switch for the pump right at the pump so I can turn it on and off from that location. I also made sure to use a fitting that was translucent so I can see when the tank is actually empty.
Yes I did find that out and moved it to where I needed. ThanksThe portion of the pump housing that has the discharge hose is movable to any location you desire
Yeah man, thanks! I’m planning to leaving around the 17thRW that looks great. Good on ya.
Now you just need to sail out 3 miles to sea to put a proper test to the system.Give it a good fill then turn the switch and let her go...
Thanks.Keep the Keel down, the sails full, and the crew well fed.
Fair winds.
