My GPS Thinks It's Yesterday!
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
Sailing today I went to check the tide info on the chartplotter, and the date was 8/05/2020 - yesterday! It's a B&G Zeus 2 MFD, using a B&G GPS antenna. There doesn't seem to be any way to correct or adjust the date and time, I assume it's coming off the satellites that way.
Anyone have any ideas?
srimes
Jun 9, 2020
211
Macgregor 26D Brookings
See what the GPS on your phone says? Mine says today. I use the app GPS test.
jviss
Feb 5, 2004
7,090
There are two GPS sources on my network, the "iGPS" and the GPS in my Vesper XB8000F AIS transponder. The latter has the wrong date. For some reason the MFD is picking up that date. I don't know how to select one source as primary. There's a configuration option on the MFD for each source called "instance" with a numerical value, but I don't know what it's for, and can't find it in the manual.
Look in the settings for a category called “network”, then an item called “sources”. On the Zeus 3 it looks like it’s possible to change the GPS source that way.
Also look for firmware updates for the Vesper. Sounds like the kind of thing a firmware update might fix.
Likes: jviss
Beneteau 323 Annapolis MD
Some people just live in the past, not the here and now. Silly goose. Yesterday IS yesterday. TODAY is TODAY. TOMORROW is tomorrow, but TODAY will be YESTERDAY. Got it? Unless you live across the international date line.
