After studying many different designs I came up with my own. My goal was to design something that was stable, universal (or easily adaptable), relatively fast to setup and can be built with standard tools in an afternoon. Feedback is encouraged.
Gin Pole
The image below is designed to start/end with the mast laying aft. It wouldn't be hard to reverse it. The angle of the gin poles would be 90 degrees in relation to the mast but it was easier to show it this way. The X that is formed by those poles "catches" the winch/halyard line at the appropriate time. In addition, I've also put a safety cable on my design to ensure disaster wont strike should it slip against the line
Sidestays
A steel pipe is used to move the pivot point to the same height as the mast step. Chains or line is used to stabilize it. A pipe flange with padding/carpet on the bottom is used to protect the deck and chainplates. The ID of the pipe should be larger than the chainplate. The gin poles are made of conduit with the bottom ends flattened. The mounting holes should be over sized to accommodate various angles. In addition, sway bar links are used to secure them to the steel pipe. This keeps everything secure while still allowing the angles to change throughout the stepping process. A pipe elbow on top of the pipe that has been cut open could reduce the likelyhood of leaving kinks in the sidestays.
Gin Pole
Sidestays
