I finally put up the longwire at home. It is only a few feet off the ground (maybe 8 feet or so) and has a buried radial. But I am hearing a lot of stations and working a few.
The antenna is fed with RG8x into an isolator and 4:1 UNUN. The length of the radial is 34 feet. Weird numbers, I know, but it works. Whoot! I can tune all bands except 12 meters. Might have to play around with that and also try and get the antenna a little higher.
I have room to lengthen and/or shorten depending on how I want to work it. I think my maximum length for the boat will be 35~37 feet. The antenna is pointing at 20 degrees. Not sure of the radiation pattern. Will have to see where the strongest signals are. Should be fun. Whoot!
