W
Will
Hi all, I have bought a 2004 Catalina and it will be arriving shortly via trailer. Basically the boat is arriving on a trailer with the mast lashed down and I want to get her in the water in maybe 3-4 days. I am trying to organize a checklist as to what I need to accomplish prior to launch. Could those of you who have gone through this offer me any help? I have a copy of the commissioning checklist and I wonder if I should just systematically go through it..... From reading the literature I know that I need to: 1)adjust the packing gland, and 2)align the engine/shaft. Any other biggies? In stepping the mast I know to check all the lights, etc. Any insight on this and what I need to be aware of? The bottom paint is good- it has been in a fresh water lake for the last two years- since new- and only has some lake scum on it which will pressure wash right off. At commissioning the hull had a barrier coat applied. No blisters detected; I plan on adding one more coat of ablative as I don't want to haul for two years.The engine has less than 40 hours on it. The previous owner changed the oil at around 20 hours. I'm thinking I should change the oil again as well. The boat will be kept in fresh water with an annual 2 week trip to the San Juans in salt water, plus 1/2 dozen 2-3 day trips in salt water to Poulsbo, Blake Island, Edmonds, and Langley (for those of you from Seattle) So far this is my list to accomplish before splashing: 1)Step the mast, 2)paint the bottom, 3)adjust packing glands, and 4)once rigging is tuned and in the water, adjust engine/shaft alignment. What else? Thanks in advance. I am moving up from a Tanzer 26 on which I did everything with great confidence-but now the C310 is a lot more complex a system.Will PapkeSeattle, WA2004 Catalina 310
