Multiple Through-Deck Fittings, Power, Ethernet, VHF
estopa
Feb 27, 2008
182
Oday 222 Milford, CT
Hi folks, hope the winter is keeping you guys busy.
I wanted to begin some research on putting a multiple through deck fitting to handle a power cable, ethernet cable, and vhf coax cable.
Right now I have one fitting for mast light. I wanted to replace it so I can run the power, ethernet and vhf coax cable. Of course it will have to also accept connectors so I can disconnect when removing the mast.
Any ideas?
estopa
Feb 27, 2008
182
Or something like this
http://www.driplug.com/products.html
[FONT=Arial, Helvetica, sans-serif]Particularly suitable for all your masthead needs. Having a 5mm 'N' type VHF connector and gland, to take cable dia 5mm. (RG58/URM43), also 3 separate glands to take 3 electric cables up to 9mm dia (0.35in) for connection to 9 contacts, each rated at 10 amps continuous up to 50 Volts. Enabling the VHF aerial, tri-colour, Anchor, steaming and deck flood light, all to be connected in on neat robust unit to save space and reduce the number of holes required in the deck by 12 or more. [/FONT]
Apr 25, 2010
104
Oday 22 Wellfleet MA
Hi George, I'm going to be interested to see what comments you get. I need to do the same thing this spring. I'm adding a mast head & Windex lights to the existing steaming lamp and adding a VHF antenna. I don't want any Aluminum parts because of the salt water environment.
John
estopa
Feb 27, 2008
182
Yeah I am wondering what the experience is between the glands (1st option) and the quick disconnect (2nd option).
I am leaning toward the 1st option, because its cheaper, and easier to install since I am just passing through the wires to the radio or battery.
Second option would be nice as a quick release when I need to step the mast. But realistically I will only do this once in spring and second in fall to put away. Also the downside is maybe loss of signal with connectors and more work to create the initial connections.
Sep 25, 2008
992
Oday 25 Gibraltar
I'd go with the connections between the deck and the mast. plugs for electrical and connectors for the coax. The problem I had with the connectors was installing them on the ends of the coax. I went with RG-8/U coax for less loss of signal and PL-259 connectors. I bought plenty of extras to practice soldering but I just couldn't get it. I had 4 connectors to install and 3 of those in position, couldn't find solderless connectors for them so I went with crimp-on connectors-
http://www.bcdxc.org/pl259_crimp_on_connectors.htm
Properly crimped and sealed and covered should work, especially if you're taking the mast down every year.
Rich
