jbushee@gmu.edu
The muffler on my 1983 30' Hunter is spraying water. A smallish, but steady stream that the bilge pumpm can handle, but water supposed to be outside the boat. Anyone with experience changing out these beasts....they sitting below the platform holding the hot water tank and fuel tank. Is ir accessible from the port side quarterberth is the plywood panel to engine compartment/hotwater tank is, perhaps, slit from top to bottom and only an aft section removed? I thik there are two bolts/clamps holdig down the muffler, but only the more forward seems to be accessible through the engine (sliding in/overt the engine to reach it. The rear clamp and rear of mullfler itself, I can't see.Anyone? Please, it's sailing season.Thanks in advance.Jerry BusheeSV Bodacious
