My muffler has developed a rusty leak. I cannot find anything like it online - looks like a 4-inch diameter, 2-foot long black steel pipe with a rubber hose entering top side (water from engine thermostat), a metal 2-inch pipe coming from the exhaust manifold into the bottom end (wrapped in what looks like a thick white insulating bandage), then the exhaust out to transom from the lower side of muffler via a 2-inch rubber hose. All mufflers I've seen have one pipe in and one out (not 2 in , 1 out). I want to remove the muffler and get it fixed/welded or replaced and have removed rubber hoses. Problem is, the metal pipe from the manifold seems to have no joints - just straight around to engine, changing to shiny corrugated pipe about half way between muffler and engine. Shall i cut it off with a hacksaw? If so, do I need to weld new one on or is there some kind of joint to connect 2 steel pipes together without welding (no experience or equipment there). Or do I have to remove the whole assembly at the manifold?
Appreciate any help out there. Thanks, Marc Lohrisch 972-464-8776 (Plano, TX)
