well
First remember, a boom made for mid-boom sheeting is usually a larger section than one made for end-boom sheeting. The stress induced in the boom is much, much higher, and if you happen to get the end of the boom in the water while headed downwind, your chances of something breaking go up immensely. You also lose leverage on the sail (imagine the boom as a wrench turning a bolt at the gooseneck), so smaller lever needs more power - you'll need to add more purchase, at least 150% what you have now, and spread it out to at least 2 or 3 plases on the boom (say, if you are 4:1, go to 6:1) unless you don't mind the sheet being sifnificantly harder to trim and a lot of stress at one point in the boom. Your call, but do it right.(Note the magnitude of the maximum stress in the attached picture: it is 3x higher for the same boom and sail with mid boom vs end boom sheeting!)
