I just added a Raymarine Rudder Position Sensor to my existing SPX-5 Autopilot. I did this because as Kloudie once put it, my AP tends to act as a drunken pilot in anything but the mildest of seas. (Hopefully Kloudie1 won't mind that I used the picture of his Rudder Stop for illustration purposes only... Thank You C)
As I went to commissioning I noticed that I would receive a “Failed Rudder Sensor” error when I went to starboard hard over. I was told this morning that the Sensor will stop responding if the angle of the rudder is too great. Therefore I will need to reduce the rudder angle. I plan to do this by drilling an additional hole in order to move the stop bar since I really do not want to drill in new screws below the cockpit deck sole.
On my H34 I go approximately 90% of a complete wheel turn when I turn to Port or Starboard. The RPS indicates that I am well over the 30% indicator. My question is 1) what is the minimum reasonable angle of deflection that the rudder should have for manual steering and 2) has anyone moved the rudder stop on their boats?
Thanks Jon
Thanks Jon
