Here is how we do it with Grampians.
Grampian actually built some O'Days back in the '70's. Note the comment about the bulkheads being part of the vessel structural support. This also applies to other makes as well - Pearson, Catalina, O'Day, C&C etc.Use 3/4" marine ply, teak or mahogany veneer each side The bulkheads are held in place with screws and not fibreglass or epoxy. You will find them behind the head, and across the top of the forward port locker. You will have to remove the centre top teak piece from between the bulkheads. This is a bit tricky but once you see the angle they used at the factory, it comes together and gets easy. You will also have to unscrew the shelving in the forepeak. You can loosen off the fore and backstays, and totally disconnect your front and rear lower shrouds, leaving just your uppers and slack front and back stays as mast support while you proceed to replace your forward bulkheads.That will take any pressure off the cabin trunk roof and make your inside work a proper fit.Don't forget - when you are all finished, always tighten up your fore and backstays much tighter than your uppers. They don't create the compression that the upper and lower shrouds do Remove the old bulkheads (both port & starboard) and use them as templates on your new 3/4" ply. Don't forget to use the old bulkheads as a template to mark where all the screws go back in. Cut out the new bulkheads, sand where necessary to get the correct fit, mount them into place with the screws, and you are good for another 15 to 20 years. (Thanks to Jim Quibell) --------------------------------------------------------------------------------Unstep the mast, or at a minimum loosen all the tension off the shrouds and forestay and backstay, to reduce the load on the cabin trunk roof. This will allow it to spring up so the new bulkheads may be fitted better. Make the bulkheads fit tight as possible into their space with the mast unstepped. The bulkheads are the structural support for the cabin trunk, mast, mainsail and boom, and all the tension on the shrouds, so you don't want any space for the trunk roof to flex downward before resting on the bulkheads. Where there are woodscrews holding the bulkheads to the hull liner, replace them with stainless machine screws, washers and nuts. Drill through the liner and put the nuts on from inside the storage lockers. Woodscrews into fiberglass are a one-shot deal and replacements don't hold very well. You can use fiberglass tape (I believe it was 2" wide tape he suggested) and epoxy to "tab" the perimeter of the bulkheads to the hull liner. As these boats have all survived 30+ years without tabbing from the factory, this addition is optional. (Tips from Gill Bibby to Tim Nye) (Back) --------------------------------------------------------------------------------How do you remove the forward bulkheads? Remove the 4 screws at the bottom of the bulkhead on the head or hanging locker side. It'll be necessary to remove the head shelf which butts up against the bulkhead. It's necessary to remove the teak trim board that bridges the port and starboard bulkheads. Should be able to remove bulkhead by pushing at bottom from v-berth side (may be necessary to "pry" off from the v berth side by inserting flat blade (i.e., screwdriver) between bulkhead and locker). There should be no screws or adhesive at top of bulkhead Special notes: The vinyl trim that runs along the top of the bulkheads contains wiring for lights on head and v berth side of the port bulkhead. The trim piece that bridges the port and starboard bulkheads is secured by 4 screws (2 on each side) slotted from the bottom and top. Carefully remove the bulkhead as you will need it as a template to construct it's replacement. (Thanks to Joe Gilmore) (Back)Go to Bulkhead Replacement for photos of one replacement project.
