Just went through this exercise with my boat on the hard.  Still not easy by any means.
Even pulling the prop requires a prop puller which uses wrenches, bolts and a bit of time to tighten it up enough for the prop to want to come off.  Even with our shaft cut in half, the back half of the shaft in a vise and the prop puller fully tensioned it took a few good hits with a small sledge to persuade it to come off.
I'm heading to the prop shop tomorrow with the 2 halves of our shaft, our prop and coupling to get a new shaft and coupling and everything 'fitted' and faced.
I think your plan A would be easier and cheaper.  I'd just worry that a strap would add more pressure to your shaft while you are sailing.  What about using elastic bungee type cord to just secure the strut and put the tranny in any gear but neutral?
