Moving a Catalina 30
Paul
Has anyone moved or shipped a Catalina 30. Do you have any advice or recommendations? What company did you use and how was the entire experience?
roger marshutz
move
I have a friend that moves an Islander 36 from SF to San Pedro. you can reach via email at: Wtfodlb@aol.com. His was a good experience. Roger
G
GREGG R. W.
C30 TRANSPORT
MOVING A C-30 IS NOT A PROBLEM AND CAN BE DONE WITH A 1-TON TRUCK OR LARGER LIKE A FORD F-550,THIS CAN BE DONE WITH A TAG TRAILER OR A GOOSENECK TRAILER.YOU WILL NEED A CDL DRIVER AND TRANSPORT PERMITS FOR EACH STATE YOU TRAVEL,THE COST FOR EACH PERMIT WILL RUN $20.00 TO $40.00 PER STATE AND GOOD FOR ABOUT TEN DAYS. ALSO YOUR BOAT WEIGHT IS ABOUT 11 TO 12K ?.,THAY NOW OFFER HEAVY DUTY RECEIVER HITCHES UP TO 16000 LBS.FOR 1-TON TRUCKS,THE TRAILER WILL NEED A EYE RING HITCH THE 25/16" BALL WILL BE TO LITE FOR THIS TYPE OF TOWING DO TO THAT YOU WILL MOST LIKELY BE OVER 12000LBS. GVWR BOAT AND TRAILER.--HOPE THIS HELPS--
