Bud, yes the cases are strapped in across the top and sides. Straps are rated to 6000lbs. I plan not to be in a position to be upside down Ron, in the attached picture you can see the scum line. I was leaning to port and aft because of the weight in the big port locker. Might need to do something else when I start stuffing the Grandkids in there this summer.JimS/V Java
starter batteries Jim? Was that factory installed or someone's paranoia? That is a really elegant solution and well implemented. Thanks for the pictorial.
The two group 27's were factory install. One starter the other house. My dear beloved wants her popcorn and movies, so needed bigger house bank. The four trojans give me a total of 450Ahrs.JimS/V Java
Jim I did something similar. Although in the pic you cant see the batteries but they in the lockers under the settee. I went with four "golfer" deep cycle 6 volt. I balanced them with two on either side up forward for balast. In series with an on/off switch up front too. One question after looking at yours. I keep shore power on when not on the boat with float on the inverter. I put my batts in cases but left the tops uncovered for ventilation/slash heat issues. Do you think you will have any issues with that? Mine fit nice and tight in the lockers. I used a tack strip to keep them from sliding backwards when im taking on a 40 foot wave NOT. Upside down! I got bigger problems than batteries moving around. What if the booze came loose! Better strap that down first.CheersRicks/v Whiskey Chaser
