the old bimini canvas was ragged so I removed it from the frame early the first summer after we bought the boat.... so now im finally ready to install my solar panel frames on my bimini bows.... afterwards I will install the new bimini canvas (already made and fitted), with grommets installed so it can be laced onto the bows.... Lacing the canvas on will allow for the use of these rail mounts I made to fit the bows, shown below...
they are made from 1" thick acetal plastic which is hard, then drilled and tapped....
the 2 aluminum frames will be mounted at 4 points each, with a 4 inch space for the backstay between them... the panels will set into the frames.
the mounts had to be 3" tall so the frames would clear the middle bow, which is naturally higher than the front and back bows...
the kyocera panels are equipped with a heavy frame for direct mounting, but my bimini bows are spaced farther fore and aft, than the panels are long, so for ease of mounting, I will build and mount the frames, and then insert the panels afterwards.
