Mounting on cabin bulkheads
Esk II
Feb 12, 2008
60
Hunter 260 Lake Arthur
This may sound stupid but I need to ask. I would like to mount some things on the cabin bulkhead or wall, possibly some curtian rods or custom shelfs. What is the best method? Is the inside wall a liner or the inside of the hull ? Can you screw or bolt items onto it?
I know the ceiling is a liner and have mounted stero equippment onto it but have never attempted to mount onto the inner bulkhead. It would provide some valuable space if one could attach items onto the surface.
Thank you, any help would be greatly appreciated. I recently received information regarding stereo installation and everything worked out perfectly, thanks to the help received on this site!!!
Earl Keim
7,743
Alden 50 Sarasota, Florida
Earl
Sounds like you may be referring to the inside of the hull rather than a bulkhead? If it is the hull to which you refer. I would guess that you don't have a hull liner but it is easy enough to tell if there is a liner to which you can fix something by looking at a thruhull anywhere on the topsides to see what it goes through.
Sep 20, 2006
2,955
Hunter 38 Georgian Bay, Ontario, Canada
Rick D
Jun 14, 2008
7,206
The product description says five pounds. I have found it varies depending on the surface area. But it is very strong stuff. The nice part is when it is removed, you can 'roll' it off without leaving a residue. Some applications on my boat: pictures, decorations, licenses in frames, teak accessory holders, DVD players, digital converter boxes, plastic shelves inside and at the helm, mirror an the back of a head door, and similar applications at home.
Esk II
Feb 12, 2008
60
HI,
This is a type of Scotch tape. Are you seriously telling me that it would hold curtian rods or a small shelf? If true life has surely become easier!! Thank you I will go to our local Lowes and give it a try. Thank you very much.
E Keim
KD3PC
1,069
boatless rainbow Callao, VA
A second vote for Rick D's tape....Kmart has it and I think in two or three strengths. We used it to mount mirrors, pictures and LED alarm clocks, LED panels. The PO used it to mount a picture and it took a serated knife to get it off...As Rick says it rubs off with no residue once you remove the mounted item...I would spring the extra $ for the 3M stuff, but have not personally tried the off brands...
Apr 22, 2008
17
Hunter 26 Boca Raton
Hey Earl,
I have used the 3M to mount a DVD player on the cabin ceiling about one year ago on my H26 and it is still there. I would get the 3M.
Joey
Esk II
Feb 12, 2008
60
Thank you all, I am sold on this tape. Life can be easy!!! Happy Easter to all and good sailing.
Earl Keim "Sin'sBad Too"
Rick D
Jun 14, 2008
7,206
Earl: not too sure about the curtain rods. Like I said, it needs enough surface area to adhere. Good luck.
Esk II
Feb 12, 2008
60
Rick and everybody who contributed,,, thank you very much I will let you all know how the project turned out. I somehow found Rick's web page, what a nice boat and crew you have!! Good weather to all.
