Jake Roquet
I am preparing my little baby for a trip to Bermuda. Has anyone mounted similar equipment for offshore:1. Liferaft, cannister type, Zodiac brand. Where did you mount it? Did you use through-mounts? If so, how did you deal with this cosmetically in the cabin. Where did you find a cradle? My limitations include the fact that I will mount my dinghy on the foredeck. It is a RIB so I can only fold it up so much. I would also like to install some additional deck cleats for my dinghy and other things. How do we know where to bolt these on deck? Again through-mounts, backplated would be preferred but how have you folks dealt with the hard liner in the cabin and unknown wiring runs?2. SSB and Tuner. I bought the ICOM. It is big and heavy. Tuner is lighter but still bulky. Where did you mount these? How did you mount these? Did you have any grounding issues when you mounted yours?3. SSB Antenna. Where the heck do you put one on the Hunter. There is no backstay. There is a product called the "Outbacker" (sp?) antenna (stern rail mount) but it is only 6' tall. I understand you do not need the tuner with this but have to change a "thingamabob" everytime you change bands. Pros and cons to this? My dealer says he would have to mount a separate wire to the mast.4. Has anyone rigged for a staysil on deck?5. Drogue. I will be using a 72" drogue. The bridle will be mounted forward to the winches. Has anyone configured this to clear the arches and stern rail?A lot to think about but maybe some of you have done this or have thoughta about the best way to mount these things. Safety and durability is key but cosmetics are important as well.It's too late to buy a different off-shore boat. And I love the 410. When I get this set-up completed I'll share mechanics with all. BTW, I have started a pretty extensive provisioning list (Excel format) I'd like to share with all. Perhaps we can make it pretty comprehensive and avoid reinventing the wheel next time you try to make the big jump. (Which it is for us.) Send me an e-mail and I'll forward it to you. (Make sure you are virus clean -- I've never had one in twenty years. My attachment to you will be clearly marked.)Thanks in advance,Jake S/V OffLinejroquet@earthlink.net
