mounting line clutches
Nov 26, 2008
1,970
Endeavour 42 Cruisin
Mounting a pair of single line clutches to the mast.
Should I use standard machine screws or self tapping screws or something else?
I'm thinking a fine thread machine screw would be best.
This will be ss screws into alum mast and yes of course I will use plenty of tef-gel
Nov 26, 2008
1,970
Happened to have a chat with a rigger this PM. Told to use 1/4 20 standard thread screws and not fine threads on aluminum
Beneteau 323 Annapolis MD
Machine screws. A theory is if you use fine threads, you'll get more threads in the mast, but corrosion will wear them away quicker. Coarse threads, and you get a better bite, but not as many threads. Are you putting these on opposite sides of the mast, and could through-bolt from one to the other?
Nov 26, 2008
1,970
John, that was what my last sentence regarding tef-gel addressed.
And forespar now sells a very similar 'teff' product
Jul 1, 1998
3,062
Oops …..
‘scuse me! Guess I read that too fast and didn’t catch it.
Thanks for the heads up about ‘teff’ - didn’t know about that. The LanoCote I’ve had for years, though, and don’t know if I’ll ever use it all up.
There’s nothing worse that a stainless fastener that is galled up in aluminum!
Nov 26, 2008
1,970
Its all good
I have teff-gel, lanocote and the Forespar Marelube Teff 45 with PTFE. I should be good for about 250 years!
Oct 2, 2008
3,811
Pearson/ 530 Strafford, NH
I had removed a clutch from my mast and after 30 years it came off with a few taps using a hand impact driver.
http://forums.sbo.sailboatowners.com/showthread.php?p=1178686&highlight=spinlock
Mine were Phillips flatheads with I believe coarse thread. I could check this weekend since its on the boat and I haven't mounted it to the mast yet. I mounted my vang (helped by a well-known forum moderator) with fine threads I believe. The trick was to turn the tap slowly and remove the shavings with a vacuum at every half turn.
I'll help the next owner of our boat by using Tef-gel.
All U Get
