A short course in hardware:
Machine screws have threads that are the same as the threads on bolts. All machine screws and bolts are designated by size first and then by the number of threads per inch. Thus you get from the very small to the very large. #2-72 is a very small screw 100 of them a 1/4 inch long would fit on a teaspoon. From there the sizes go 4-40, 6-32, 8-32, 10-24 & 10-32, 12-24, 1/4-20 & 1/4-28 etc. The sizes run up to where one bolt is a load to carry. You can purchase Fine thread bolts and Course thread bolts. The label will indicate 10-24 NC or 10-32 NF etc.Bolt and screws also come in a variety of head styles Round head stands proud on the surface, Flat head has a cone shape underside and requires a counter sink to make it fit properly (hinge screws are an example)Oval head screws are like a flat head screw but the top of the head is a little rounded. After this comes the familar square head and hexagon heads on bolts.I hope this is more help than harm .
