Motor Trailering Mount Done
JerryA
Oct 17, 2004
550
Hunter Hunter 170 Sandusky Bay, Lake Erie
I made my mount to hold my motor while trailering my 170. I used a piece of galvanized "U" channel and added a piece of wood to the inside giving me the same thickness as the boat motor mount. I made a nest at the bottom from 4" PVC and a galvanized bracket. I made the top bracket big enough to hold a gas outboard if I ever decide that I'd like to try one. Now to make the fixture to hold the rudder and tiller in the boat while trailering. :)
Rick S.
Good job!
Jerry, Thanks for posting the pic. Looks like a good solution -- simple, sturdy, and low-cost. Now if you can just figure out a way to make that prop spin windmill-style in the slipstream so you can charge the battery for free during the drive to the marina....:) I plan to build a similar mount for my 2-hp. Hope you'll share a picture or description of your fixture for the rudder and tiller, too, when the time comes.
E
Edwin
Sonuvagun
Been trying to figure out a way to do this - your's is a lot simpler than what I was thinking of. Knew the forums would be good for something.
