Motor mount
Oct 21, 2012
88
Macgregor 22 Lake Texoma Tx
I have a 22 macgregor and I got A new motor mount for it how low do you mount it ? I have a exta long 9.9 four stroke
Joe
Jun 1, 2004
8,260
Are you saying the motor mount didn't come with installation instructions? You will need measurements particular to your motor and the transom of your vessel to determine optimal location. What brand motor mount did you purchase. How much vertical travel?
Joe
Jun 1, 2004
8,260
If you know the brand of mount you can simply google it for instructions. Here's an example from Garelick Heavy duty aluminum mount for 4 strokes... but they should all be similar. Note that they use a stick, rather than the motor itself, taped to the mount in order to get the positioning correct. They also recommend 5/16 ss bolts for attachment. Also note that there is a sailboat example on the second page of this document. http://garelick.com/files/12.295.pdf
