Motor mount replacement
12
- - Bohemia River, Maryland
I have a little vibration sound comming from one of my mounts on a 95-336. Should I change all four mounts and can I do this job myself. Please advise.
Dec 2, 2003
4,245
- - Seabeck WA
First check it to make sure the adjusting nuts are
tight. A rubber mount should make NO noise.
Jun 3, 2004
42
Catalina 34MKII 1717 Merritt Island, FL
can be done
i was able to do it with the help of a buddy and some 3'pry-bars.the job was a little messy and took maybe 2 hours. my boat is a 1989 33.5. your boat, i believe, has much better access to the engine. the shaft has to be aligned after replacing the mounts. the engine guy i use stated that the mounts should be replaced in pairs,2 port, 2 starboard. if you are the least bit mechanical, chill a 12 pack of good beer and give it a try..
