can be done
i was able to do it with the help of a buddy and some 3'pry-bars.the job was a little messy and took maybe 2 hours. my boat is a 1989 33.5. your boat, i believe, has much better access to the engine. the shaft has to be aligned after replacing the mounts. the engine guy i use stated that the mounts should be replaced in pairs,2 port, 2 starboard. if you are the least bit mechanical, chill a 12 pack of good beer and give it a try..
