I could probably get a better picture in a couple hours . . . .but I think you can see this.
My motor mount is only held on by 4 screws (I’m assuming they are screws). last year I noticed a little movement in the bracket when lowering it. I had hoped to put this repair off until next year (haven’t launched yet and have a couple more jobs to do) except now I notice the stress cracks in the gelcoat, indicating more movement than I thought I had. There is another hole just below the screw that is failing, a quick and dirty fix would just be to put another screw in to try to share the burden. I feel like the real answer is remove it, clean everything up, start from scratch (repair the gelcoat).
so 2 questions: is this urgent? and how do I repair it?
also, should I replace the motor mount? It’s really hard to push down, and that‘s probably what’s causing the stress, not sure how hard it’s supposed to be to push down, but I’ve never gotten it to it’s lowest position.
