Motor bracket
Justin
Apr 10, 2012
16
Preditor 240 Adelaide
I am looking at replacing the motor bracket on a hunter 240. Just wondering if anyone has replaced one recently? And if so how they went about it? I was thinking or attempting to make it adjustable in order to get the leg of the engine which when in the upright position currently drags in the water.
-na -NA Anywhere USA
There has been a lot of discussion on this. The first question when dragging, its the shat the extra long shaft? If so, it is too long and I would suggest talking with a dealer to see what it would cost to get a 20 shaft.
When putting an adjustable outboard motor bracket on, just remember you are adding weight to the area where the bracket attaches too and that is a must consideration. Anyway, look in the archives as this has been reviewed in the past which should give you some good responses.
