Motor Anodes
Mar 26, 2017
32
Irwin 38 Palacios
Hello All,
I recently had my 1985 citation pulled out for repair. While it was out I changed the shaft anode and the bracket anode.
My question is do most motors have a "pencil" anode inserted in the motor? I have a Yamamar diesel in my boat and have inspected all the parts I can see without pulling cabinetry apart but see no anode "plug."
Do I need one, or is the shaft and bracket protection enough??
Nov 6, 2006
10,247
The 3GM series Yanmars do not have anodes on the fresh water cooled engines..If you have a Yanmar of the mid '80's, with a heat exchanger, it probably does not have anodes.
EDIT: If the engine does not have a heat exchanger, it will have anodes, 3; one on the aft end of the cylinder head, and 2, in the block, under the exhaust manifold. They are bigger than the pencil ones; about 1" in diameter with a large hex head.
