Ed
So often, I hear what should be on the boat.Lets start with the trailer. Get it. It is easier to haul and the price is cheaper with the boat as you would have to pay for shipping a second time if you got the trailer later.I would say about 5% of the 260 sailboats have tiller. Most folks like the idea of the wheel as it is easier to steer. Also, the tiller will swing into the seats and folks have to move. As for resale, there is no question that you would be able to sell the boat quicker versus the tiller.Roller fuling is a must. It is a pain to hank on the jib. In the event of high winds, you would want to reduce the jib first and with roller furling, that can be accomplished. Not many folks go up forward anyway unless to get the anchor out.Interior cloth cushions is a must. I hate the vinyl which are standard. Many reasons for them but I will ask if you like sitting on cold or hot vinyl. Stern rail seats is of course is a choice but I have found that many women like this feature plus some men. Also, it will give you a life line situation completely around the boat which is a safety concern.Bimini is a must particulay in the south.As for the engine, that is a choice but for what it is, do not get anything over a 9.9 hp. The motor mount is rated up to 10 hp only. I lost a friend over this subject as I told him flat out 15 was too much. I have seen the result of a twisted and/or damaged motor bracket plus the fact you are plowing and the bow of the boat raises up thus slowing the boat down. I do suggest that you get the electric start with an alternator to recharge your battery. Use quick disconnects for the electrical line that the bass boats use for the trolling motors. In some states, two stroke are outlawed for example in California. However, the two stroke have improved greatly in the past two years as they were forced to by EPA which basically are quieter and more fuel efficient. With a four stroke you still have to check the oil from time to time plus if the motor is off, there is only one way to lay it on the ground or the oil will seep out of the motor. I like the 9.8 by Tohatsu which is the same on the Nissan and I belive Mercury 9.8 too.as for instruments, I like the ST-40 bidata. It is easy to install if you know what you are doing. If you are sailing and concerned with radio, then get a VHF radio. It is a toss up between hand held or mast head antenna but remember that the VHF is line of sight and the higher it is, the further you will reach which is why I recommend the mast head antenna.Bottom painting. Are you simply going to trailer your boat and if so, you do not need to do that. If you do plan to leave the boat in the water, then you will need it. Suggest Micron CSC because the effectiveness of the paint will remain the same for the following season if you take the boat out. Some anti fouling paints will loose their pontential if the boat is out for more than 60 days. Frank Ladd is correct that you will void warranty if you sand the bottom. There is an ok if you scotch brite the bottom scuffing it up but you have to get the ok from Hunter first. I suggest that you get the dealer to do it. Make sure that the bottom has been cleared of the mold wax. I clean it three times even though the instructions say once. Better to be safe than sorry. Use of Petit 6999 non sanding primer is greatly recommended and apply the first coat of paint while the non sanding primer is still tacky.Yes there are other options like shore power, central heat and air conditioning, and so forth. Some dealers would have to farm this out as they lack the expertise and eqipment which may be one reason why the cost is higher. If you are going to purchase a 260, then the best time to deal is getting all the equipment that you anticipate for the next five years and see if the dealer will give you a package price that both of you can live with.If you need any further insight, feel free to ask me on this forum. I realize this is long but hopefully this will help you.Crazy dave condon
