More Yanmar mixing elbow
Bob F
Most of the suggestions for replacment/cleaning of the elbow use time as the determining factor. What about use or engine hours? I only put 60-70 hours per year on the engine. Thanks. Bob.
Paul F
Jun 3, 2004
827
Hunter 1980 - 33 Bradenton
may depend on your engine
Like you I only put on limited hours a year. I have an older 2qm15, which is original on a 1980 Hunter 33' purchased four years ago. This winter was the first time I had the mixing elbow off. After taking it off, I hammered the rust around the end of the elbow attached to the exhaust hose to enable fitting on a new hose. Other than that, the elbow was almost clean inside. I cleaned it as best I could at deckside and reinstalled it. I would recommend taking yours off for an inspection. Then, you will know what you have rather than guess.
Feb 24, 2004
29
NULL NULL Boatless in Seattle
Exhaust water
You should be getting a good strong gush of water out of the exhaust every few seconds. if not the cost to replace the elbow is far less then a new engine.
Bill O'Donovan
Here's the key
Try to run the engine at its sweet spot as much as possible, and preferably 2 hours a month to blow it out. The mistake people make is to run the thing slow, thinking they're saving the engine. In fact, they're clogging it.
