Planning a solar project for the boat. I would like to use 2 140W Kyocera panels and 1 90W Solarland (Kyocera KC85T Replacement) to fit on top of bimini. Is the difference in voltage or amps going to create a problem with the MPPT controller? And any suggestions for a highly recommended controller would be appreciated. Another question is would I connect the 3 panels in parallel? I have read several articles on solar topics and have searched this forum to find information to be of great value but I am still feeling a little confused in some areas. I am sure I will have more questions in the near future and any suggestions would be great.
Kyocera 140 Watt 12 Volt Specs:
Ratings:
Voltage 17.7 VDC
Current*7.91 Amps
Power 140W
Solarland 90 Wat 12 Volt Spec:
Ratings:
Voltage 17.2 VDC
Curent 5.23 Amps
Power 90W
Ratings:
Voltage 17.7 VDC
Current*7.91 Amps
Power 140W
Ratings:
Voltage 17.2 VDC
Curent 5.23 Amps
Power 90W
