More on water tank problems
944
Birch Bay Washington
Further investigationn indicates that the white substance is some kind of salt which is the result of corrosion. The spotted areas are seriously and deeply pitted under the salt deposits. Cutting access holes indicates that the corrosion is mostly on the welded areas. Comment from a welder suggests that the reason for the other spots of corrosion is that the areas where these spots occured is probably where the welding material spattered. I wonder if proper welding techniques and materials were used. 1.Any welders out there with thoughts on this theory? I am aware of the deletorious health consequences of aluminum consumption IE: suspected connection to alzheimers disease. I am considering some kind of non-metallic replacement tank. 2. Has anyone done this? This boat is a 37.5 and there is a nearly useless storage area forward of the water tank. I am considering putting the new water tank further forward into the very front of the bow and using the space left under the v-berth for drawers or some other more useful storage. 3. Any ideas on this modification? 4. How will moving the tank forward affect the balance or handling of the boat?
Dec 2, 1997
9,011
- - LIttle Rock
I'd replace the tank with a plastic tank
A good quality plastic water tank that's been properly cured for water holding will NOT give water a "plastic" taste. Many sailboats have bow shaped water or waste tanks all the way forward...it shouldn't affect your boat's performance enough to notice...although hard-core racers will recommend draining or pumping out a tank in the bow to race. Ronco Plastics has over 100 non-rectangular tanks (more than 400 total shapes and sizes)...their catalog is at http://www.ronco-plastics.com Their prices are VERY reasonable and they install fittings in the sizes and locations specified by the customer when they make the tank.
Jun 7, 2004
944
Polyurethane coating
Anybody ever tried this stuff? http://www.sanitred.com/
