Bubaloo
Hunter 31 (1984) under construction and I have a few more questions. You guys have been a huge help so far. Thanks.RobI want to replace the bushing/bearing (cutlass?) in front of the prop. It has a little slop. Both prop nuts are off. How do I get the prop off and bearing out? Do I pull the shaft? Is the bushing pressed in? Where do I find a replacment?The stuffing box seemed to wok well on sea trial last year. Is there any maintenance I should do on it while the boat is out of the water?Has anybody found a replacment for the base on the table? New seacocks...plastic or metal?What gauge wire would you use for a steaming/deck light? Where can I find a new mast plug?
