Randy
The morning began with more of the same problem I experienced about 2 months ago. Could not discharge toilet bowl. Was fighting tremendous back pressure. Remembering the advice of two months ago the first thing I checked was for a clogged tank vent. That was OK. Disasembled pumping mechanism and found the base valve to be broken. Aha! Problem solved. Replaced base valve and still experienced same pressure. Removed cap to holding tank just to insure tank was not pressurized.Still experienced back pressure. Disconnected vent line from tank. Still had pressure. I think I have narrowed it down to a clogged discharge hose. But when I fill the bowl with water I experience back pressure. I am at a loss to as to why I would have back pressure when filling the bowl. I eliminated any problems with the pumping mechanism by disconnecting the discharge hose from the pump. Pump works fine. Any ideas? Oh BTY the head is a Jabsco manual operation.
