from the professional boatbuilder
Most of what people say here is correct. Early (1972-1980) Hunters were built with NO hull core. This is always better. The only reason for core is to add thickness and reduce weight and cost. No production Hunter of this era had less than about 35% of its total displacement in ballast weight (mine is over 40%!), so weight savings in the rest of the boat was not an issue. Personally I would eschew cored hulls in all but high-perf applications. It is actually more complex and costs more in labor (though the core materials are almost always cheaper than the polyester resin and cloth for an equivalent thickness). Nowadays vinylester-resin lay-ups return about another 10% weight savings and add complete water impermeability, so even today a cored hull is at best a gimmick.
Decks are another matter, because you want to save weight at such an elevation above the waterline for stability's sake alone. In most production situations the deck is finished as far as possible before being turned over to be installed on the hull. In high-volume situations the deck should be removed from the mold pronto to get another deck going into a mold. Hunter used to build one boat in each of 5 production lines per day. Nowadays someone like Catalina could probably shoot two or three decks a day.
All electrical wiring, mounting pads for deck hardware, the soft headliner, etc., gets installed with the deck upside-down. The idea in production is to advance each stage as far as possible before initiating another stage. As owners we all know how hard it is to do restoration, repair and remodeling over our heads-- did you think the builders would do that by choice?
Very few modern boatbuilders would use a plywood core. Plywood is a major sponge for water, it is heavy, it is expensive, and it needs to be treated before installation (to be done right). The foam used as cores is (supposedly) closed-cell and will not soak up water. (We've all seen how well that claim holds up.) In the '70s the favorite solution was edge-grained balsa, by nature a water sponge, except that balsa is used because it is light, cheap (imported) and floats when waterlogged. This, too, rots when allowed to stay wet. (I have written on how to fix this many times.)
At Cherubini my cousin Dave made a new deck mold for the C44 in which he included SOLID 'glass bedding blocks for major deck hardware. These require no additional backing plates. I would suspect nowadays most builders do something similar (but we never had a deck mold before and so his 'glass backing plates are a whopping new thing to me).
My 1974 boat has a flange molded on the hull about 3-4" wide, on which the deck sits. This is how my dad wanted it and is the preferred method for fastening the two parts together. Other methods are the 'shoebox method' (deck has sides that fit down over top edge of hull-- MacGregor and others do this) and the 'kissy face method' (both deck and hull flare out like frog lips and the two flared flanges are mated and covered with a metal molding-- common in cheap motorboats). With the metal toerail on my boat, the deck/flanged hull/toerail combination is absolutely unbeatable-- quick to assemble, cheap, and phenomenally strong; and with the toerail adequately bedded in 5200, it won't even leak.
I don't have experience with assembling full-interior molded liners and voted against them when I had any influence on Hunter. (I am pretty sure my dad never designed one.) I find them heavy, complicated, and prone to causing nightmares for maintenance down the line. Of course both the hull and deck liners have to go in before assembly of the hull and deck-- but I see no reason to fasten them together. Leaving an actual gap between the edge of the deck (head-) liner and the interior liner pan allows for the inevitable moisture/water to seep out. Also, unless the space between a liner and the hull or deck were filled completely with foam, it would be hard to through-bolt any bit of hardware to either side of it. At least if it were foam you could use the 'spade bitt method' (drill oversize and fill the local void with epoxy before drilling bolt holes). A total (air) gap would be, again, a nearly-unsolvable nightmare for this. Liners with air gaps also lend a rumble from vibrations that sounds like you're in living in Alex VanHalen's kick drum.
Filling this void with plywood would be heavy, expensive, and pointless; so if you're seeing plywood in a few cut-outs it may only be in very local areas (round the flange for example, or under a mast step). Even then it would not be reliable.
Owners of early H25s will be aware that the deck under the mast step is cored with foam; but the mast step sits on a fiberglass plate integral with the hatch hood and under that is plywood. (I cut off my hatch hood short, filled the foam with epoxy and added a G-10 plate on the deck for it = better.)
In the case of partial hull pans, such as in the C44, it is possible to fit all the associated equipment, engine, toilet, whatever, and so on before picking the whole thing up and installing it. But, again, full-molded pans can lead to nightmares. Cheap motorboats are made entirely in sections-- to the point where they will often have a beautiful molded cockpit pan installed over top of a fuel tank, through-hulls, fuel hoses, wiring, etc, that will never be accessible again without a pneumatic hacksaw. ('The boatbuilder is not always your friend,' I used to say to my West Marine customers.)
So I am skeptical of the use of molded interior liners when it leads to builders achieving too high a level of assembly before permanently attaching to the hull assembly. If you've ever had an inaccessible fixture below one (H37 owners, you know what I mean) you'll know why this is not the way to go. Apparently even Hunter fell prey to the 'quickly-done is quickly-paid' mentality by about 1978 as well
More and more each day I am glad my 1974 boat is essentially 'stick-built' after all.
