Read this only if you are not a product liability attorney:
In searching for the zen of teak care, I have found that the secret ingredients in two-part teak care products are lye and oxalic acid, both mixed at less than 5% solution in water according to some MSDS sheets I've viewed. Part 1 is the lye. Part 2 is the oxalic acid. Rather than pay $30 to $100 for quart or gallon bottles of pre-mixed solutions, a 1 lb. can of lye can be had for about $5.00, and West Marine sells Oxalic acid for $12 per lb (about twice the going market price) in a concentration that will yield four gallons of working solution.
Also, my research on teak oils shows that most are based on diluted linseed oil as previously mentioned here. Linseed oil will not waterproof wood, it darkens considerable with age, and it promotes growth of mold that turns the wood gray. A better choice can be Tung oil, which is said to create a waterproof surface that can be shiny if enough oil is applied, it will not promote mold, and it is said to darken less than linseed oil with age. One source I read said that by applying successively heavier coats of Tung oil, an almost varnish like surface can be created. Unlike varnish however, the oil finish will expand and contract with the wood so that it will not crack or flake off. The problem with Tung oil on teak is getting it to soak into the oily wood. I have read that this can be aided by thinning it 50% with mineral spirits. Thinning is also how one builds up successively heavier coats, simply reduce the amount of thinner for each successive coat, until the last one is applied full strength.
I intend to try this this weekend. I'll post results.
