Think about your mooring for a minute
John -The guys are right about the possibility of pulling bow eye out. It could happen if what you've got isn't in good shape. That's why the first part of my comment is to make sure the bow eye on your boat is strong and well secured. If it is, its the perfect place to attach to.With respect to the guys who are afraid the thing is going to chafe through, I disagree. If your bow eye is quality stainless, and the fitting you attach it to is also quality stainless, you will need decades to wear it appreciably. If you use cheap stuff, all bets are off. You could get galvanic corrosion, and if there are barbs on the fitting it could score the bow eye. But, if they're both high quality, smooth, polished stainless, I really don't think you'll have a problem. Think about your mooring for a moment. You have chain with is a lot less smooth than your bow eye rubbing on shackles that are also a whole lot less smooth than your bow eye. But they don't chafe through.If you were really worried about it, coat the fitting in one of the rubber products designed for tool handles, or run a line through the bow eye and secure it to itself.Why am I so hung up on this? Because the bow eye is really the right angle for the mooring to be attached. First, its going to result in better holding power for your ground tackle. By decreasing the height of the attachment point you will increase the relative scope of the mooring mushroom and increase its effectiveness. At the same time, you will no longer be trying to pull the bow of the boat down into chop. It will be free to ride up and over stuff resulting in a lot less stress to the boat, and lots smoother motion for equipment, and people, aboard.I attached my daysailer to her mooring using the bow eye and it worked great for me. If my Catalina had a bow eye, I'd moor her on it too. Good luck with whatever you choose to do.Justin - O'day Owners' Web
