Mooring setup
87
Hunter 23 Pennsville
right here
Its pretty much an auger with an eyelet at the top, through which you'd pass a bar to screw it into the bottom. These are becomeing more frequent as mooring options, obviously they are easier to install than large concrete block or mushroom anchors, they have a much higher holding potential, and allow for a shorter scope on the mooring line. If you can't get them from Helix, I'm sure you can find a vendor somewhere. Check the section on roundshaft anchors as well. These would be for lower weight, less permanent anchorage.
Oct 19, 2006
337
Hunter 27-3 Brownsville, VT/Mystic, CT
Emailed Helix
Androctus, I emailed the company to ask for their recommendation & a local dealer. Thanks again!
