Mooring a C-22
Scott
How big of a mushroom moring would it take to hold a C-22 in heavy winds? I am thinking around 100 LBS. but not sure if it is enough.
John J
Mooring
The West Marine catalog has some pretty good information on this subject. It will give you the answer you need.
jkleid
mooring
not only will the size /weight be a factor, but the soil conditions into which it will be anchored
Ted
200 lbs.
that should hold it. I think 100 lbs would not do. Regards, Ted
E
Eric Landis
200 lbs also
I agree with all previous replies. I will also add that length of chain and mooring line is equally important. A heavier mushroom won't help if the boat is lifting it off the bottom. A 1 to 3 (rise to run) maximum slope is recommended for high tide I believe. Don't skimp on the heavy bottom chain, as that is what forces the mushroom do its job correctly (i.e. on its side)
