This season I've noticed slight leaks starting around two through bolts so I've decided to rebed everything with butyl tape as a winter project.
That leads to two questions:
What does the minimum outside temperature have to be for butyl to adhere to the deck and hardware properly?
Is there an inexpensive pinless moisture meter anyone would recommend for to check around each thu-deck fitting for moisture?
Thanks,
Jim
Thanks,
Jim
