Recently purchased a 2003 326. Survey indicated small amount of moisture in rudder. He indicated it was not a huge problem now, but recommended drilling a small hole in base of rudder to let water drain out before I drop in the spring. Before dropping he said to insert threaded insert into hole than screw in machine screw. Of course all will be sealed with sealant. Has anyone heard of doing this.
