Dick's idea and another
Dick's idea, in combination with RickW's rudder lock (which a person should have anyway) should certainly give some relief.Here's a new idea. It may apply more to the H23.5 (1995 or earlier) than the H26 because the H23.5 has only a single horizontal bar on the transom rail (see the link to RickW's picture in a previous post of mine). The H26 and the 1996 H23.5 have a higher transom rail that has two horizontal bars.Anyway, my bar is below knee hight and nearly useless. I sail with my mast crutch in place so there is something to grab on to. When I added stern rail seats I put a lifeline between the tops of the two seats across the transom.I wouldn't totally remove the transom rail, as it holds up the swim ladder and is there to grab in some cases, but what about cutting out a 2 inch section, and putting a sliding SS sleeve over it. Drill a hole for a quick release pin that is secured with a lanyard so it doesn't get lost. Slide the sleeve to open the gap, and then lift the tiller to the nearly vertical position.On a rail with two cross bars, perhaps this would only be necessary on the lower bar, used in combination with Dick's idea and a rudder lock.I'm thinking that having the tiller quickly available is a safety feature if you wake up to find that you've gragged anchor or something. Plus, you don't have to stow it somewhere as when totally removed....RickM...
