Peter Hine
My 27 is an OB model. I just bought a new Johnson 15HP LS 2 stroke, which fits in the well with only a little modifcation. However, in order to avoid the lower unit hitting the rudder when under power, I've had to tilt the OB up to position #3 on the tilt adjust. This causes the OB to push the stern down when at high throttle, the lazarette fills w/water, and the motor's powerhead sits right at water level on the stern wave. I'm considering cutting a notch in the rudder to allow it to miss the lower unit at a more "full down" tilt setting. Anybody done this? Any problems? Is there a better way? (And no, I'm not going to use a transom bracket!)
