Preference for Fixed Keel Model
Clay,Thanks for the information. I like the fixed keel due to the absence of through hulls, and the CB not getting jammed with mud or barnacles when moored in a shallow cove. The fixed keel is also the same draft as the rudder, so the rudder can't get knocked off by obstacles in shallow water, or low tides in a cove! I like the smaller mast for ease of handling during haul out, and fitting under a bridge when going out into the bay. The smaller mainsail (76 sq ft) makes the boat very steady regardless of wind strength (or gusts) and gives a "big boat" feel. I don't race, so upwind performance is not an issue. For casual, comfortable sailing, the boat can't be beat! I have considered the CB/Keel model if I can't find a good late "cruising" model with no core rotin the cabin top or deck!I have also owned an ODay23 (CB/Keel) which is just a litle larger than I want now. I am an experienced sailor, having owned and sailed a lightning (2), Blue Jay, 30 ft Gaff Rigged Ketch (Tahiti), ODay 22 and ODay23. It is time to "down size" a bit!!Tony Ganz
